| Command | Description |
| deny (ipv4-acl) | Creates a deny access rule or modifies an existing rule. A deny access rule rejects packets from specified address(es) and/or destined for specified address(es). |
| disable (ipv4-acl) | Disables an existing deny or permit rule without removing it from the ACL |
| insert (ipv4-acl) | Inserts a rule in an IP ACL without overwriting or replacing an existing rule having the same precedence |
| permit (ipv4-acl) | Creates a permit access rule or modifies an existing rule. A permit access rule accepts packets from specified address(es) and/or destined for specified address(es). |
| no (ipv4-acl) | Removes a deny and/or a permit access rule from a IP ACL |
For more information on common commands (clrscr, commit, help, revert, service, show, write, and exit), see Common Commands.
