vrrp-state-check
Profile Config Commands
Publishes interface via OSPF or BGP based on Virtual Router Redundancy Protocol (VRRP) status
VRRP allows automatic assignment of available IP routers to participating hosts. This increases the availability and reliability of routing paths via automatic default gateway selections on an IP subnetwork. This option is enabled by default.
Syntax
vrrp-state-check
Parameters
None
nx9500-6C8809(config-device-B4-C7-99-6C-88-09)#vrrp-state-check
nx9500-6C8809(config-device-B4-C7-99-6C-88-09)#show context
nx9000 B4-C7-99-6C-88-09
 use profile default-nx9000
 use rf-domain default
   no weight
  no timers bgp
  ip default-gateway priority 7500
  bgp-route-limit num-routes 10 retry-count 5 retry-timeout 60 reset-time 360
 vrrp-state-check
 controller adopted-devices controllers
 alias string $SN B4C7996C8809
Related Commands
no Disables the publishing of an interface via OSPF/BGP based on VRRP status
