no (router-mode-config-command)
Removes this OSPF router settings or reverts them to default values
Syntax
no [area|auto-cost|default-information|ip|network|ospf|passive|redistribute|
route-limit|router-id]
Parameters
no <PARAMETERS>
no <PARAMETERS> Negates a command or set its defaults
Usage Guidelines
The no command negates any command associated with it. Wherever required, use the same parameters associated with the command getting negated.
The following example shows the OSPF router interface settings before the ‘no‘ commands are executed:
nx9500-6C8809(config-profile default-ap8533-router-ospf)#show context
 router ospf
  network 1.2.3.0/24 area 4.5.6.7
  area 0.0.0.4
  auto-cost reference-bandwidth 1
  default-information originate metric 1 metric-type 2
  redistribute static metric-type 1
  passive vlan1
  route-limit num-routes 10 reset-time 10
  ip default-gateway priority 1
nx9500-6C8809(config-profile default-ap8533-router-ospf)#no area 4
nx9500-6C8809(config-profile default-ap8533-router-ospf)#no auto-cost reference-bandwidth
nx9500-6C8809(config-profile default-ap8533-router-ospf)#no network 1.2.3.0/24 area 4.5.6.7
The following example shows the OSPF router interface settings after the ‘no‘ commands are executed:
 router ospf
  passive vlan1
