ex3500
Creates an EX3500 time range list and enters its configuration mode
An EX3500 time range list consists of a set of periodic and absolute time range rules. Periodic time ranges recur periodically at specified time periods, such as daily, weekly, weekends, weekdays, and on specific week days, for example on every successive Mondays. Absolute time ranges are not periodic and do not recur. They consist of a range of days during a particular time period (the starting and ending days and time are fixed).
The EX3500 series switch is a Gigabit Ethernet layer 2 switch with either 24 or 48 10/100/1000-BASE-T ports, and four Small Form-factor Pluggable (SEP) transceiver slots for fiber connectivity. The EX3500 series switch can adopt to a NOC controller and be managed by it. The EX3500 time range values configured here are used in EX3500 MAC ACL firewall rules that filter an EX3500‘s incoming and outgoing traffic.
For more information on creating EX3500 rules, see ex3500 (mac-acl-config-commands).
Syntax
ex3500 time-range <TIME-RANGE-NAME>
Parameters
ex3500 time-range <TIME-RANGE-NAME> Configures EX3500 time range list and enters its configuration mode
  • <TIME-RANGE-NAME> – Enter a name for this time range. If the time range does not exist, it is created.
nx9500-6C8809(config)#ex3500 time-range EX3500_TimeRange_02
nx9500-6C8809(config-ex3500-time-range-EX3500_TimeRange_02)#?
nx9500-6C8809 Time Range Configuration commands:
  absolute  Absolute time and date
  no        Negate a command or set its defaults
  periodic  Periodic time and date
  clrscr    Clears the display screen
  commit    Commit all changes made in this session
  do        Run commands from Exec mode
  end       End current mode and change to EXEC mode
  exit      End current mode and down to previous mode
  help      Description of the interactive help system
  revert    Revert changes
  service   Service Commands
  show      Show running system information
  write     Write running configuration to memory or terminal
Related Commands
no Removes this EX3500 time range list
