telnet
Opens a Telnet session between two network devices
This command and its syntax is common to both the User Executable and Privilege Executable configuration modes.
Syntax
telnet <IP/HOSTNAME> {<TCP-PORT>} {<INTF-NAME>}
Parameters
<IP/HOSTNAME> Configures the destination remote system‘s IP (IPv4 or IPv6) address or hostname. The Telnet session is established between the connecting system and the remote system.
  • <IP/HOSTNAME> – Specify the remote system's IPv4 or IPv6 address or hostname.
<TCP-PORT> Optional. Specify the Transmission Control Protocol (TCP) port number.
<INTF-NAME> Optional. Specify the interface name for the link local address.
nx9500-6C8809#telnet 10.234.160.37
Entering character mode
Escape character is '^]'.
AP510 release 7.3.1.0-001D
ap510-133B38 login:
