mint-policy
Configures the global MiNT policy and
enters its configuration mode
- Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
Syntax
mint-policy global-default
Parameters
global-default |
Configures the global default MiNT policy |
nx9500-6C8809(config)#mint-policy global-default
nx9500-6C8809(config-mint-policy-global-default)#?
Mint Policy Mode commands:
level Mint routing level
lsp LSP
mtu Configure the global Mint MTU
no Negate a command or set its defaults
router Mint router
udp Configure mint UDP/IP encapsulation
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
![Note](images/note.png)
For more information on MiNT policy configuration, see
MiNT Policy.
