sensor-policy-config-commands
The following table summarizes sensor-policy configuration mode commands:
Table 1. Sensor Policy Config Mode Commands
Command Description
custom-scan Configures the channel scanning settings when the scan-mode is set to custom-scan
rssi-interval-duration Configures the interval at which dedicated sensors scan channels for RSSI assessments and send the collected data to a specified MPact server resource
scan-mode Configures the mode of scanning used by dedicated sensors (access point radios)
no (sensor-policy-config-mode-commands) Removes or reverts to default a sensor policy‘s settings
