led
Profile Config Commands
Turns on and off access point LEDs
Syntax
led {flash-pattern}
Parameters
led {flash-pattern}
led flash-pattern Optional. Enables LED flashing on the device using this profile
Select this option to flash an access point‘s LEDs in a distinct manner (different from its operational LED behavior). Enabling this feature allows an administrator to validate an access point has received its configuration (perhaps remotely at the site of deployment) without having to log into the managing controller or service platform. This feature is disabled by default.
nx9500-6C8809(config-profile-TestAP8533)#led flash-pattern
nx9500-6C8809(config-profile-TestAP8533)#show context
profile ap8533 TestAP8533
 no autoinstall configuration
 no autoinstall firmware
 led flash-pattern
 crypto ikev1 policy ikev1-default
  isakmp-proposal default encryption aes-256 group 2 hash sha
 crypto ikev2 policy ikev2-default
 crypto ipsec transform-set default esp-aes-256 esp-sha-hmac
 crypto ikev1 remote-vpn
 crypto ikev2 remote-vpn
 crypto auto-ipsec-secure
 --More--
Related Commands
no Disables or reverts settings to their default
