no (area-config-mode-command)
Removes this OSPF area settings
Syntax
no [area-type|authentication|range]
Parameters
no <PARAMETERS>
no <PARAMETERS> Removes this OSPF area settings
Usage Guidelines
The no command negates any command associated with it. Wherever required, use the same parameters associated with the command getting negated.
The following example shows the OSPF router settings before the ‘no‘ commands are executed:
nx9500-6C8809(config-profile default-nx5500-router-ospf-area-0.0.0.1)#show context
  area 0.0.0.1
   authentication simple-password
   range 172.16.10.0/24
   area-type stub default-cost 1
nx9500-6C8809(config-profile default-nx5500-router-ospf-area-0.0.0.1)#no authentication
nx9500-6C8809(config-profile default-nx5500-router-ospf-area-0.0.0.1)#no range
172.16.10.0/24
The following example shows the OSPF router settings after the ‘no‘ commands are executed:
  area 0.0.0.1
