reconnect-interval
Configures the interval, in seconds, between successive attempts to re-establish a failed tunnel connection
Syntax
reconnect-interval <1-3600>
Parameters
Configures the interval between successive attempts to re-establish a failed tunnel connection
  • <1-3600> – Specify a value from 1 - 3600 seconds (default is 120 seconds).
nx9500-6C8809(config-l2tpv3-policy-L2TPV3Policy1)#reconnect-interval 100
l2tpv3 policy L2TPV3Policy1
 hello-interval 200
 cookie-size 8
 reconnect-attempts 8
Related Commands
no
Resets the interval between successive attempts to re-establish a failed tunnel connection to default (120 seconds)
