bootfile (dhcpv4-pool-config)
The Bootfile command provides a diskless node path to the image file while booting up. Only one file can be configured for each DHCP pool.
For more information on the BOOTP protocol with reference to the DHCP policy, see bootp bootp (dhcpv4-server-policy-config).
Syntax
bootfile <IMAGE-FILE-PATH>
Parameters
<IMAGE-FILE-PATH>
Sets the path to the boot image for BOOTP clients. The file name can contain letters, numbers, dots and hyphens. Consecutive dots and hyphens are not permitted.
rfs4000-229D58(config-dhcp-policy-test-pool-testPool)#bootfile test.txt
rfs4000-229D58(config-dhcp-policy-test-pool-testPool)#show context
 dhcp-pool testPool
  address 192.168.13.4 class dhcpclass1
  bootfile test.txt
Related Commands
no
Resets the boot image path for the BOOTP clients
Configures BOOTP protocol parameters
