disable-connected-check (bgp-neighbor-config)
Enables one-hop away eBGP peer using loop back address. This option is disabled by default.
Syntax
Parameters
None
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#disable-connected-check
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#show context
  bgp neighbor 192.168.13.99
   advertisement-interval 100
   allowas-in 10
   attribute-unchanged as-path
   capability orf prefix-list both
   default-originate
   description neighbor "This neighbor is an external AS neighbor"
Related Commands
no (bgp-neighbor-config) Disables one-hop away eBGP peer using loop back address
