Release 7.9.4.0
Revision AB
The following updates have been made in Revision AB of this guide.
Updates Description
gre (show command)
gre
gre concentrator
Added the concentrator command.
This command allows you to configure a GRE concentrator profile which enables a ExtremeWireless WiNG controller to operate as a terminator for GRE tunnels configured on ExtremeCloud IQ managed Universal APs running IQ Engine OS. GRE concentrator supports up to 1000 GRE tunnel terminations.
Smart-RF Policy
smart-rf-policy commands
smart-sensor
smart-sensor-status-timer
Added the smart-sensor-status-timer command. This command is associated with smart-rf-policy commands, and works in conjunction with the smart-sensor command. When the configured timer interval expires, the RF Domain Manager checks the status of radio sensors. If the status of the sensors is Off, recalibration for the smart-sensor feature is triggered.
Revision AA
The following updates have been made in Revision AA of this guide.
Update Description
iot-device-type-imagotag Updated the show iot-device-type-imagotag status command to include Claim ID in the status output. The Claim ID is a 16-digit hash-code that needs to be passed to SES-imagotag V:Cloud database after USB-Dongle FW update.
aggregation Corrections have been made to this interface-config-radio-instance command syntax.
