bgp router-config
Use the (device-config) or (profile-config) instance to configure BGP router related parameters.
To navigate to the BGP router configuration instance, in the device-config mode, use the following commands:
<DEVICE>(config)#self
<DEVICE>(config-device-<MAC>)#router bgp
<DEVICE>config-device <MAC>-router-bgp)#
<DEVICE>config-device <MAC>-router-bgp)#?
Router BGP Mode commands:
  aggregate-address   Configure aggregate address
  asn                 Configure local Autonomous System Number
  bgp                 Border Gateway Protocol
  bgp-route-limit     Limit for number of routes handled by BGP process
  distance            Configure administrative distance
  ip                  Internet Protocol (IP)
  network             Configure a local network
  no                  Negate a command or set its defaults
  route-redistribute  Redistribute information from another routing protocol
  timers              Adjust routing timers
  clrscr              Clears the display screen
  commit              Commit all changes made in this session
  do                  Run commands from Exec mode
  end                 End current mode and change to EXEC mode
  exit                End current mode and down to previous mode
  help                Description of the interactive help system
  revert              Revert changes
  service             Service Commands
  show                Show running system information
  write               Write running configuration to memory or terminal
When configured as a profile, the router settings are applied to all devices using the profile.
To navigate to the BGP router configuration instance, in the profile-config mode, use the following commands:
<DEVICE>(config)#profile <DEVICE-TYPE> <PROFILE-NAME>
<DEVICE>(config-profile-<PROFILE-NAME>)#router bgp
<DEVICE>(config-profile <PROFILE-NAME>-router-bgp)#
<DEVICE>(config-profile <PROFILE-NAME>-router-bgp)#?
The following table summarizes BGP router configuration mode commands:
Table 1. BGP-Router Config Mode Commands
Command Description
aggregate (bgp-router-config) Creates and configures an aggregate address entry in the BGP database
asn (bgp-router-config) Configures this BGP router‘s ASN
bgp (bgp-router-config) Configures BGP router parameters
bgp-route-limit (bgp-router-config) Configures the BGP route limit parameters
distance (bgp-router-config) Configures administrative distance parameters
ip (bgp-router-config) Configures the BGP default gateway‘s priority
network (bgp-router-config) Configures the local network IP addresses and masks
route-redistribute (bgp-router-config) Enables redistribution of routes learnt from other routing protocols into BGP
timers (bgp-router-config) Enables adjustment of keepalive and holdtime intervals
no (bgp-router-config) Removes the BGP router settings
