ip (bgp-router-config)
Configures the BGP default gateway‘s priority
- Service Platforms — NX9500, NX9600
Syntax
ip default-gateway priority <1-8000>
Parameters
| default-gateway priority <1-8000> |
Configures the default gateway‘s (acquired through BGP)
priority
- <1-8000> – Specify a value from 1 - 8000. The default is 7500. Lower the
value, higher is the priority.
nx9500-6C8809(config-profile testNX9000-router-bgp)#ip default-gateway priority 1
nx9500-6C8809(config-profile testNX9000-router-bgp)#show context
router bgp
bgp enable
asn 1
bgp-route-limit num-routes 10
nx9500-6C8809(config-profile testNX9000-router-bgpp)#
