assignable-power
Configures the Smart RF power settings over 2.4 GHz, 5.0 GHz, and 6.0 GHz radios.
Syntax
assignable-power [2.4GHz|5GHz|6GHz] [max|min] <1-20>
Parameters
2.4GHz [max|min] <1-20>
Assigns a power range on the 2.4 GHz band
  • max <1-20> – Sets the upper limit from 1 dBm - 20 dBm (default is 17 dBm)
  • min <1-20> – Sets the lower limit from 1 dBm - 20 dBm (default is 4 dBm)
5GHz [max|min] <1-20>
Assigns a power range on the 5.0 GHz band
6GHz [max|min] <1-20>
Assigns a power range on the 6.0 GHz band
nx9500-6C8809(config-smart-rf-policy-test)#assignable-power 2.4GHz max 20
nx9500-6C8809(config-smart-rf-policy-test)#assignable-power 2.4GHz min 8
nx9500-6C8809(config-smart-rf-policy-test)#show context
smart-rf-policy test
 area test channel-list 2.4GHz 1,2,3
Related Commands
no (smart-rf-policy-config-mode-command)
Resets assignable power to its default
