event
Configures events, filters and threshold values for this WIPS policy. Events are grouped into three categories, AP anomaly, client anomaly, and excessive. WLANs are baselined for matching criteria. Any deviation from this baseline is considered an anomaly and logged as an event.
By default all event monitoring is disabled.
Syntax
event [ap-anomaly|client-anomaly|enable-all-events|excessive]
event ap-anomaly [ad-hoc-violation|airjack|ap-ssid-broadcast-in-beacon|asleap|
impersonation-attack|null-probe-response|transmitting-device-using-invalid-mac|
unencrypted-wired-leakage|wireless-bridge]
event client-anomaly [dos-broadcast-deauth|fuzzing-all-zero-macs|
fuzzing-invalid-frame-type|fuzzing-invalid-mgmt-frames|fuzzing-invalid-seq-num|
identical-src-and-dest-addr|invalid-8021x-frames|netstumbler-generic|
non-conforming-data|wellenreiter] {filter-ageout <0-86400>}
event enable-all-events
event excessive [80211-replay-check-failure|aggressive-scanning|auth-server-failures|
decryption-failures|dos-assoc-or-auth-flood|dos-eapol-start-storm|dos-unicast-deauth-or-disassoc|
eap-flood|eap-nak-flood|frames-from-unassoc-station] {filter-ageout <0-86400>|
threshold-client <0-65535>|threshold-radio <0-65535>}
Parameters
ap-anomaly
Enables AP anomaly event tracking
An AP anomaly event refers to suspicious frames sent by neighboring APs. An administrator enables or disables the filtering of each listed event and sets the thresholds for the generation of event notification and filtering.
ad-hoc-violation
Tracks ad-hoc network violations
airjack
Tracks AirJack attacks
Tracks AP SSID broadcasts in beacon events
asleap
Tracks ASLEAP attacks. These attacks break LEAP (Lightweight Extensible Authentication Protocol) passwords
Tracks impersonation attacks. These are also referred to as spoofing attacks, where the attacker assumes the address of an authorized device.
null-probe-response
Tracks null probe response attacks
transmitting-device-using- invalid-mac
Tracks the transmitting device using an invalid MAC address
Tracks unencrypted wired leakage
wireless-bridge
Tracks WDS (wireless bridge) frames
event client-anomaly [dos-broadcast-deauth|fuzzing-all-zero-macs|fuzzing-invalid-frame-type|
fuzzing-invalid-mgmt-frames|fuzzing-invalid-seq-num|identical-src-and-dest-addr|invalid-8021x-frames|
netstumbler-generic|non-conforming-data|wellenreiter] {filter-ageout <0-86400>}
client-anomaly
Enables client anomaly event tracking
These are suspicious events performed by wireless clients that compromising the security of the network. An administrator can enable or disable the filtering of each listed event and set the thresholds required for the generation of the event notification and filtering action applied.
Tracks DoS broadcast deauthentication events
Tracks Fuzzing: All zero MAC addresses observed
Tracks Fuzzing: Invalid frame type detected
Tracks Fuzzing: Invalid management frame detected
Tracks Fuzzing: Invalid sequence number detected
Tracks identical source and destination addresses detection
Tracks Fuzzing: Invalid 802.1x frames detected
netstumbler-generic
Tracks Netstumbler (v3.2.0, 3.2.3, 3.3.0) events
non-changing-wep-iv
Tracks unchanging WEP IV events
non-conforming-data
Tracks non conforming data packets
wellenreiter
Tracks Wellenreiter events
The following keywords are common to all of the above client anomaly events:
  • filter-ageout <0-86400> – Optional. Configures the filter expiration time in seconds
    • <0-86400> – Sets the filter ageout time from 0 - 86400 seconds. The default is 0 seconds.
Note: For each violation define a filter time in seconds, which determines how long the packets (received from an attacking device) are ignored once a violation has been triggered. Ignoring frames from an attacking device minimizes the effectiveness of the attack and the impact to the site until permanent mitigation can be performed.
The filter ageout value is applicable across the entire RF Domain using this WIPS policy. If an MU is detected performing an attack and is filtered by one of the APs, the information is passed on to all APs and controllers within the RF Domain through the domain manager. Consequently the MU is filtered, for the specified period of time, across all devices.
enable-all-events
Enables tracking of all intrusion events (client anomaly and excessive events)
auth-server-failures|decryption-failures|dos-assoc-or-auth-flood|dos-eapol-start-storm|
dos-unicast-deauth-or-disassoc|eap-flood|eap-nak-flood|frames-from-unassoc-station]
{filter-ageout [<0-86400>]|threshold-client [<0-5535>]|threshold-radio <0-65535>}
excessive
Enables the tracking of excessive events. Excessive events are actions performed continuously and repetitively. These events can impact the performance of the controller managed network. DoS attacks come under this category.
Tracks 802.11replay check failure
aggressive-scanning
Tracks aggressive scanning events
Tracks failures reported by authentication servers
decryption-failures
Tracks decryption failures
Tracks DoS association or authentication floods
Tracks DoS EAPOL start storms
dos-unicast-deauth-or- disassoc
Tracks DoS dissociation or deauthentication floods
eap-flood
Tracks EAP floods
eap-nak-flood
Tracks EAP NAK floods
Tracks frames from unassociated clients
The following keywords are common to all excessive events:
  • filter-ageout <0-86400> – Optional. Configures a filter expiration time in seconds. It sets the duration for which the client is filtered. The client is added to a ACL as a special entry and frames received from this client are dropped.
    • <0-86400> – Sets a filter ageout time from 0 - 86400 seconds. The default is o seconds.
Note: This value is applicable across the RF Domain. If a client is detected performing an attack and is filtered by one of the APs, the information is passed to the domain controller. The domain controller then propagates this information to all APs and wireless controllers in the RF Domain.
  • threshold-client <0-65535> – Optional. Configures a client threshold value after which the filter is triggered and an event is recorded
    • <0-65535> – Sets a wireless client threshold value from 0 - 65535 seconds
  • threshold-radio <0-65535> – Optional. Configures a radio threshold value after which the filter is triggered and an event is recorded
    • <0-65535> – Sets a radio threshold value from 0 - 65535 seconds
nx9500-6C8809(config-wips-policy-test)#event excessive 80211-replay-check-failure
filter-ageout 9 threshold-client 8 threshold-radio 99
nx9500-6C8809(config-wips-policy-test)#show context
wips-policy test
 event excessive 80211-replay-check-failure threshold-client 10 threshold-radio 99 filter-ageout 9
 event client-anomaly wellenreiter filter-ageout 99
 ap-detection-ageout 50
 ap-detection-wait-time 15
Related Commands
no (wips-policy-config-mode-command)
Disables WIPS policy events tracking
