group
Configures a wireless client filter based on the RADIUS group name
Syntax
group [any|contains|exact|not-contains]
group [any|contains <WORD>|exact <WORD>|not-contains <WORD>]
Parameters
group
Specifies a wireless client filter based on how the RADIUS group name matches the provided expression. Select one of the following options: any, contains, exact, or not-contains.
any
This user-defined role can fit into any group (no strings to match). This is the default setting.
contains <WORD>
The role is applied only when the RADIUS group name contains the string specified in the role.
  • <WORD> – Specify the string to match (this is case sensitive, and is compared against the group name returned by the RADIUS server). It should contain the provided expression.
exact <WORD>
The role is applied only when the RADIUS group name exactly matches the string specified in the role.
  • <WORD> – Specify the exact string to match (this is case sensitive, and is compared against the group name returned by the RADIUS server). It should be an exact match.
not-contains <WORD>
The role is applied only when the RADIUS group name does not contain the string specified in the role.
  • <WORD> – Specify the string not to match (this is case sensitive, and is compared against the group name returned by the RADIUS server). It should not contain the provided expression.
nx9500-6C8809(config-role-policy-test-user-role-testing)#group contains testgroup
nx9500-6C8809(config-role-policy-test-user-role-testing)#show context
 user-role testing precedence 10
  authentication-type eq kerberos
  encryption-type eq wep128
  ap-location contains office
  captive-portal authentication-state pre-login
  city exact SanJose
  company exact Example_company
  country exact America
  department exact TnV
  emailid exact testing@examplecompany.com
  employeeid contains TnVTest1
Related Commands
no
Removes the group configured for this user-defined role
