default-router (dhcpv4-pool-static-binding)
Configures a default router or gateway IP address for the static binding configuration. After a DHCP client has booted, the client begins sending packets to its default router.
Syntax
default-router [<IP>|<HOST-ALIAS-NAME>] {<IP1>|<HOST-ALIAS-NAME1>}
Parameters
[<IP>|<HOST-ALIAS- NAME>]
Configures the primary default router, using one of the following options:
  • <IP> – Specifies the primary default router‘s IP address
  • <HOST-ALIAS-NAME> – Specifies a host alias, mapped to the primary default router‘s IP address
{<IP1>|<HOST-ALIAS- NAME1>}
Optional. Configures the secondary default router, using one of the following options:
  • <IP1> – Specifies the secondary default router‘s IP address
  • <HOST-ALIAS-NAME1> – Specifies a host alias, mapped to the secondary default router‘s IP address. If the primary default router is unavailable, the secondary router is used.
Note: A network host alias maps a name to a single network host. For example, ‘alias host $HOST 1.1.1.100‘. In this example the host alias is ‘$HOST‘ and it maps to a single host ‘1.1.1.100‘. For more information, see alias.
Note: A maximum of 8 default routers can be configured.
Usage Guidelines
The IP address of the router should be on the same subnet as the client subnet.
nx9500-6C8809(config-dhcp-policy-test-pool-pool1-binding-test)#default-router 172.16.10.8 172.16.10.9
nx9500-6C8809(config-dhcp-policy-test-pool-pool1-binding-test)#show context
  static-binding client-identifier test
   client-name RFID
   bootfile test.txt
Related Commands
no (dhcpv4-pool-static-binding)
Removes the default router settings
