customize
Customizes the output of the summary CLI commands. Use this command to define the data displayed as a result of various show commands.
Syntax
customize [cdp-lldp-info-column-width|hostname-column-width|show-adoption-status|
show-wireless-client|show-wireless-client-stats|show-wireless-client-stats-rf|
show-wireless-meshpoint|show-wireless-meshpoint-accelerated-multicast|
show-wireless-meshpoint-neighbor-stats|show-wireless-meshpoint-neighbor-stats-rf|
show-wireless-mint-client|show-wireless-mint-client-stats|
show-wireless-mint-client-stats-rf|show-wireless-mint-portal|
show-wireless-mint-portal-stats|show-wireless-mint-portal-stats-rf|
show-wireless-radio|show-wireless-radio-stats|show-wireless-radio-stats-rf]
customize [cdp-lldp-info-column-width|hostname-column-width] <1-64>
customize show-adoption-status (adopted-by,ap-name <1-64>,cdp-lldp-info,
config-status,last-adoption,msgs,uptime,version)
customize show-wireless-client (ap-name <1-64>,auth,client-identity <1-32>,bss,
enc,hostname <1-64>,ip,last-active,location <1-64>,mac,radio-alias <3-67>,radio-id,
radio-type,role <1-32>,state,username <1-64>,vendor,vlan,wlan)
customize show-wireless-client-stats (hostname <1-64>,mac,rx-bytes,rx-errors,
rx-packets,rx-throughput,t-index,tx-bytes,tx-dropped,tx-packets,tx-throughput)
customize show-wireless-client-stats-rf (average-retry-number,error-rate,
hostname <1-64>,mac,noise,q-index,rx-rate,signal,snr,tx-rate)
customize show-wireless-meshpoint-accelerated-multicast
(ap-hostname,group-addr,mesh-name,neighbor-hostname,neighbor-ifid,radio-alias,
radio-id,radio-mac,subscriptions)
customize show-wireless-meshpoint (ap-mac,cfg-as-root,hops,hostname <1-64>,
interface-ids,is-root,mesh-name <1-64>,mpid,next-hop-hostname <1-64>,next-hop-ifid,
next-hop-use-time,path-metric,root-bound-time,root-hostname <1-64>,root-mpid)
customize show-wireless-meshpoint-neighbor-stats (ap-hostname <1-64>,
neighbor-hostname <1-64>,neighbor-ifid,rx-bytes,rx-errors,rx-packets,rx-throughput,
customize show-wireless-meshpoint-neighbor-stats-rf (ap-hostname <1-64>,
average-retry-number,error-rate,neighbor-hostname <1-64>,neighbor-ifid,noise,q-index,
rx-rate,signal,snr,t-index,tx-rate)
customize show-wireless-mint-client (client-alias <1-64>,client-bss,
portal-alias <1-64>,portal-bss,up-time)
customize show-wireless-mint-client-stats (client-alias <1-64>,
portal-alias <1-64>,portal-bss,rx-bytes,rx-errors,rx-packets,rx-throughput,t-index,
customize show-wireless-mint-client-stats-rf (average-retry-number,
client-alias <1-64>,error-rate,noise,portal-alias <1-64>,portal-bss,q-index,rx-rate,
signal,snr,tx-rate)
customize show-wireless-mint-portal (client-alias <1-64>,client-bss,
customize show-wireless-mint-portal-stats (client-alias <1-64>,client-bss,
portal-alias <1-64>,rx-bytes,rx-errors,rx-packets,rx-throughput,t-index,tx-bytes,
customize show-wireless-mint-portal-stats-rf (average-retry-number,
client-alias <1-64>,client-bss,error-rate,noise,portal-alias <1-64>,q-index,rx-rate,
signal,snr,tx-rate)
customize show-wireless-radio (adopt-to,ap-name <1-64>,channel,location <1-64>,
num-clients,power,radio-alias <3-67>,radio-id,radio-mac,rf-mode,state)
customize show-wireless-radio-stats (radio-alias <3-67>,radio-id,radio-mac,
rx-bytes,rx-errors,rx-packets,rx-throughput,tx-bytes,tx-dropped,tx-packets,
tx-throughput)
customize show-wireless-radio-stats-rf (average-retry-number,error-rate,
noise,q-index,radio-alias <3-67>,radio-id,radio-mac,rx-rate,signal,snr,t-index,
tx-rate)
Parameters
hostname-column-width <1-64>
Configures default width of the hostname column in all show commands
  • <1-64> – Sets the hostname column width from 1 - 64 characters
cdp-lldp-info-column-width <1-64> Configures the column width in the show > cdp/lldp > [neighbor|report] command output
  • <1-64> – Sets the column width from 1 - 64 characters
show-adoption-status Configures the information displayed in the show > adoption > status command output. Select the columns (information) displayed from the following options: adopted-by, ap-name, cdp-lldp-info, config-status, last-adoption, msgs, uptime, and version. These are recursive parameters and you can select multiple options at a time.
The columns displayed by default are: Device-Name, Version, Config-Status, MSGS, Adopted-By, Last-Adoption, and Uptime.
Where ever available, you can optionally use the <1-64> parameter to set the column width.
bss,enc,hostname <1-64>,ip,last-active,location <1-64>,mac,radio-alias <3-67>,
radio-id,radio-type,role <1-32>,state,username <1-64>,vendor,vlan,wlan)
Customizes the show > wireless > client command output
The columns displayed by default are: MAC, IPv4, Vendor, Radio-ID, WLAN. VLAN, and State.
ap-name <1-64>
Includes the ap-name column, which displays the name of the AP with which this client associates
  • <1-64> – Sets the ap-name column width from 1 - 64 characters
auth
Includes the auth column, which displays the authorization protocol used by the wireless client
Includes the client-identity (device type) column, which displays details gathered from DHCP device fingerprinting feature (when enabled). For more information, see client-identity.
  • <1-32> – Sets the client-identity column width from 1 - 32 characters
bss
Includes the BSS column, which displays the BSS ID the wireless client is associated with
enc
Includes the enc column, which displays the encryption suite used by the wireless client
hostname <1-64>
Includes the hostname column, which displays the wireless client's hostname
ip
Includes the IP column, which displays the wireless client's current IP address
last-active
Includes the last-active column, which displays the time of last activity seen from the wireless client
location <1-64>
Includes the location column, which displays the location of the client's associated Access Points
  • <1-64> – Sets the location column width from 1 - 64 characters
mac
Includes the MAC column, which displays the wireless client's MAC address
radio-alias <3-67>
Includes the radio-alias column, which displays the radio alias with the AP's hostname and radio interface number in the "HOSTNAME:RX" format
  • <3-67 – Sets the radio-alias column width from 3 - 67 characters
radio-id
Includes the radio-id column, which displays the radio ID with the AP's MAC address and radio interface number in the "AA-BB-CC-DD-EE-FF:RX" format
radio-type
Includes the radio-type column, which displays the wireless client's radio type
role <1-32>
Includes the role column, which displays the client's role
  • <1-32> – Sets the role column width from 1 - 32 characters
state
Includes the state column, which displays the wireless client's current availability state
username <1-64>
Includes the username column, which displays the wireless client's username
  • <1-64> – Specify the username column width from 1 - 64 characters.
vendor
Includes the vendor column, which displays the wireless client's vendor ID
vlan
Includes the VLAN column, which displays the wireless client's assigned VLAN
wlan
Includes the WLAN column, which displays the wireless client's assigned WLAN
Customizes the show > wireless > client stats command output
The columns displayed by default are: MAC, Tx bytes, RX bytes, Tx pkts, Rx pkts, and Tx bps, RX bps, T-Index, and Dropped pkts.
hostname <1-64>
mac
rx-bytes
Includes the rx-bytes column, which displays the total number of bytes received by the wireless client
rx-errors
Includes the rx-error column, which displays the total number of errors received by the wireless client
rx-packets
Includes the rx-packets column, which displays the total number of packets received by the wireless client
rx-throughput
Includes the rx-throughput column, which displays the receive throughput at the wireless client
t-index Includes the t-index column, which displays the traffic utilization index at the particular wireless client
tx-bytes
Includes the tx-bytes column, which displays the total number of bytes transmitted by the wireless client
tx-dropped
Includes the tx-dropped column, which displays the total number of dropped packets by the wireless client
tx-packets
Includes the tx-packets column, which displays the total number of packets transmitted by the wireless client
tx-throughput
Includes the tx-throughput column, which displays the transmission throughput at the wireless client
customize show-wireless-client-stats-rf (average-retry-number,error-rate,noise,
q-index,rx-rate,signal,snr,t-index,tx-rate)
Customizes the show > wireless > client stats RF command output
The columns displayed by default are: MAC, Signal (dBm), Noise (dBm), SNR (dB), TX Rate (Mbps), Retry Avg, Errors (pps), and Q-Index (%).
Includes the average-retry-number column, which displays the average number of retransmissions made per packet
error-rate
Includes the error-rate column, which displays the rate of error for the wireless client
hostname <1-64>
mac
noise
Includes the noise column, which displays the noise (in dBm) as detected by the wireless client
q-index
Includes the q-index column, which displays the RF quality index
Note: Higher values indicate better RF quality.
rx-rate
Includes the rx-rate column, which displays the receive rate at the particular wireless client
signal
Includes the signal column, which displays the signal strength (in dBm) at the particular wireless client
snr
Includes the snr column, which displays the signal-to-noise (SNR) ratio (in dB) at the particular wireless client
t-index
tx-rate
Includes the tx-rate column, which displays the packet transmission rate at the particular wireless client
customize show-wireless-meshpoint-accelerated-multicast (ap-hostname,group-addr,
mesh-name,neighbor-hostname,neighbor-ifid,radio-alias,radio-id,radio-mac,subscriptions)
show-wireless-meshpoint-accelerated-multicast Configures the information displayed in the show > wireless > meshpoint > accelerated multicast command output. Select the columns (information) displayed from the following options: ap-hostname, group-addr, mesh-name, neighbor-hostname, neighbor-ifid, radio-alias, radio-id, radio-mac, subscriptions. These are recursive parameters and you can select multiple options at a time.
The columns displayed by default are: Mesh, Radio, Neighbor-IFID, Neighbor-Hostname, Group-MAC, and Subscriptions.
Customizes the show > wireless > meshpoint command output
The columns displayed by default are: Mesh, Hostname, Hops, Is-Root, Config-As-Root, Root-Hostname, Root-Bound-Time, Path-Metric, Next-Hop-Hostname, and Next-Hop-Use-Time.
ap-mac
Includes the ap-mac column, which displays the AP's MAC address in the AA-BB-CC-DD-EE-FF format. Applicable only in case of non-wireless controller meshpoints
cfg-as-root
Includes the cfg-as-root column, which displays the configured root state of the meshpoint
hops
Includes the hops column, which displays the number of hops to the root for this meshpoint
hostname <1-64>
Includes the hostname column, which displays the AP's hostname. Applicable only in case of non-wireless controller meshpoints
interface-ids
Includes the interface-ids column, which displays the interface identifiers (interfaces used by this meshpoint)
is-root
Includes the is-root column, which displays the current root state of the meshpoint
mesh-name <1-64>
Includes the mesh-name column, which displays the meshpoint's name
  • <1-64> – Sets the mesh-name column width from 1 - 64 characters
mpid
Includes the mpid column, which displays the meshpoint identifier in the AA-BB-CC-DD-EE-FF format
Includes the next-hop-hostname column, which displays the next-hop AP's name (the AP next in the path to the bound root)
  • <1-64> – Sets the next-hop-hostname column width from 1 - 64 characters
next-hop-ifid
Includes the next-hop-ifid column, which displays the next-hop interface identifier in the AA-BB-CC-DD-EE-FF format
next-hop-use-time
Includes the next-hop-use-time column, which displays the time since this meshpoint started using this next hop
root-bound-time
Includes the root-bound-time column, which displays the time since this meshpoint has been bound to the current root
Includes the root-hostname column, which displays the root AP's hostname to which this meshpoint is bound
  • <1-64> – Sets the root-hostname column width from 1 - 64 characters
root-mpid
Includes the root-mpid column, which displays the bound root meshpoint identifier in the AA-BB-CC-DD-EE-FF format
neighbor-hostname <1-64>,neighbor-ifid,rx-bytes,rx-errors,rx-packets,rx-throughput,t-index,
Customizes the show > wireless > meshpoint > neighbor > stats command output
The columns displayed by default are: AP Hostname, Neighbor-IFID, TX bytes, RX bytes, Tx pkts, Rx pkts, Tx (bps), Rx (bps), T-Index (%), and Dropped pkts.
ap-name <1-64>
Includes the ap-name column, which displays name of the AP reporting a neighbor
Includes the neighbor-hostname column, which displays the reported neighbor's hostname
  • <1-64> – Sets the neighbor-hostname column width from 1 - 64 characters
neighbor-ifid
Includes the neighbor-ifid column, which displays the neighbor's interface ID
rx-bytes
Includes the rx-bytes column, which displays the total bytes received
rx-errors
Includes the rx-error column, which displays the total bytes of error received
rx-packets
Includes the rx-packets column, which displays the number of packets received
rx-throughput
Includes the rx-throughput column, which displays neighbor's received throughput
t-index Includes the t-index column, which displays the traffic utilization index at the neighbor end
tx-bytes
Includes the tx-bytes column, which displays the total bytes transmitted
tx-dropped
Includes the tx-dropped column, which displays the total bytes dropped
tx-packets
Includes the tx-packets column, which displays the number of packets transmitted
tx-throughput
Includes the tx-throughput column, which displays neighbor's transmitted throughput
Customizes the show > wireless > meshpoint > neighbor > statistics RF command output
The columns displayed by default are: AP Hostname, Neighbor-IFID, Signal (dBm), Noise (dBm), SNR (dB), Tx-Rate (Mbps), Rx-Rate (Mbps), Retry Avg, Errors (pps), and Q-Index (%).
ap-name <1-64>
Includes the average-retry-number column, which displays the average number of retransmissions made per packet.
error-rate
Includes the neighbor-hostname, which displays reported neighbor's hostname
noise
Includes the noise column, which displays the noise level in dBm
q-index
Includes the q-index column, which displays the q-index
rx-rate
Includes the rx-rate column, which displays rate of receiving
signal
Includes the signal column, which displays the signal strength in dBM
snr
Includes the snr column, which displays the signal-to-noise ratio
t-index
Includes the t-index column, which displays t-index
tx-rate
Includes the tx-rate column, which displays rate of transmission
customize show-wireless-mint-client (client-alias <1-64>,client-bss,portal-alias <1-64>,portal-bss,up-time)
show-wireless-mint-client Configures the information displayed in the show > wireless > mint > client command output. Select the columns (information) displayed from the following options: client-alias, client-bss, portal-alias, portal-bss, and up-time. These are recursive parameters and you can select multiple options at a time.
The columns displayed by default are: Portal, Portal-Radio-MAC, Client, Client-Radio-MAC, and Up-Time.
customize show-wireless-mint-client-stats (client-alias <1-64>,portal-alias <1-64>,
portal-bss,rx-bytes,rx-errors,rx-packets,rx-throughput,t-index,tx-bytes,tx-dropped,
show-wireless-mint-client-stats Configures the information displayed in the show > wireless > mint > client > statistics command output. Select the columns (information) displayed from the following options: client-alias, portal-alias, portal-bss, rx-bytes, rx-errors, rx-packets, rx-throughput, t-index, tx-bytes, tx-dropped, tx-packets, tx-throughput. These are recursive parameters and you can select multiple options at a time.
The columns displayed by default are: Portal, Portal-Radio-MAC, Client, Tx bytes, Rx bytes, TX pkts, Rx pkts, TX (bps), Rx (bps), T-Index (%), and Dropped pkts.
signal,snr,tx-rate)
show-wireless-mint-client-stats-rf Configures the information displayed in the show > wireless > mint > client > statistics > rf command output. Select the columns (information) displayed from the following options: average-retry-number, client-alias, error-rate, noise, portal-alias, portal-bss, q-index, rx-rate, signal, snr, and tx-rate. These are recursive parameters and you can select multiple options at a time.
The columns displayed by default are: MAC, Signal (dBm), Noise (dBm), SNR (dB), Tx-Rate (Mbps), Rx-rate (Mbps), Retry Avg, Errors (pps), and Q-Index (%).
show-wireless-mint-portal Configures the information displayed in the show > wireless > mint > portal command output. Select the columns (information) displayed from the following options: client-alias, client-bss, portal-alias, portal-bss, and up-time. These are recursive parameters and you can select multiple options at a time.
The columns displayed by default are: Client, Client-Radio-MAC, Portal, Portal-Radio-MAC, and Up-Time.
Where ever available, optionally use the <1-64> parameter to set the column width.
signal,snr,tx-rate)
show-wireless-mint-portal-stats-rf Configures the information displayed in the show > wireless > mint > portal > statistics > rf command output. Select the columns (information) displayed from the following options: average-retry-number, client-alias, client-bss, error-rate, noise, portal-alias, q-index, rx-rate, signal, snr, tx-rate. These are recursive parameters and you can select multiple options at a time.
The columns displayed by default are: Client, Client-Radio-MAC, Portal, Signal (dBm), Noise (dBm), SNR (dB), Tx-Rate (Mbps), Rx-rate (Mbps), Retry Avg, Errors (pps), and Q-Index (%).
show-wireless-radio
Customizes the show wireless radio command output
adopt-to
Includes the adopt-to column, which displays information about the wireless controller adopting this AP
ap-name <1-64>
Includes the ap-name column, which displays information about the AP this radio belongs
channel
Includes the channel column, which displays information about the configured and current channel for this radio
location <1-64>
Includes the location column, which displays the location of the AP this radio belongs
num-clients
Includes the num-clients column, which displays the number of clients associated with this radio
power
Includes the power column, which displays the radio's configured and current transmit power
radio-alias <3-67>
Includes the radio-alias column, which displays the radio's alias (combination of AP's hostname and radio interface number in the "HOSTNAME:RX" formate)
  • <3-67> – Sets the radio-alias column width from 3 - 67 characters
radio-id
Includes the radio-id column, which displays the radio‘s ID (combination of AP's MAC address and radio interface number in the "AA-BB-CC-DD-EE-FF:RX" format)
radio-mac
Includes the radio-mac column, which displays the radio's base MAC address
rf-mode
Includes the rf-mode column, which displays the radio's operating mode. The radio mode can be 2.4 GHz, 5.0 GHz, 6.0 GHz, bridge, or sensor.
state
Includes the state column, which displays the radio's current operational state
tx-throughput)
Customizes the show wireless radio statistics command output
radio-alias <3-67>
Includes the radio-alias column, which displays the radio's alias (combination of AP's hostname and radio interface number in the "HOSTNAME:RX" format)
radio-id
radio-mac
rx-bytes
Includes the rx-bytes column, which displays the total number of bytes received by the radio
rx-errors
Includes the rx-error column, which displays the total number of errors received by the radio
rx-packets
Includes the rx-packets column, which displays the total number of packets received by the radio
rx-throughput
Includes the rx-throughput column, which displays the receive throughput at the radio
tx-bytes
Includes the tx-bytes column, which displays the total number of bytes transmitted by the radio
tx-dropped
Includes the tx-dropped column, which displays the total number of packets dropped by the radio
tx-packets
Includes the tx-packets column, which displays the total number of packets transmitted by the radio
tx-throughput
Includes the tx-throughput column, which displays the transmission throughput at the radio
customize show-wireless-radio-stats-rf (average-retry-number,error-rate,noise,
-index,radio-alias <3-67>,radio-id,radio-mac,rx-rate,signal,snr,t-index,tx-rate)
Customizes the show wireless radio stats RF command output
Includes the average-retry-number column, which displays the average number of retransmissions per packet
error-rate
Includes the error-rate column, which displays the rate of error for the radio
noise
Includes the noise column, which displays the noise detected by the radio
q-index
radio-alias <3-67>
radio-id
radio-mac
rx-rate
Includes the rx-rate column, which displays the receive rate at the particular radio
signal
Includes the signal column, which displays the signal strength at the particular radio
snr
Includes the snr column, which displays the signal-to-noise ratio at the particular radio
t-index
Includes the t-index column, which displays the traffic utilization index at the particular radio
tx-rate
Includes the tx-rate column, which displays the packet transmission rate at the particular radio
The following example shows the shows the show > adoption > status command output before customizing the output:
rfs4000-229D58#show adoption status
Adopted by:
Type          : nx9000
System Name   : nx9500-6C8809
MAC address   : B4-C7-99-6C-88-09
MiNT address  : 19.6C.88.09
Time          :   4 days 22:38:32 ago
Adopted Devices:
DEVICE-NAME       VERSION         CFG-STAT         MSGS ADOPTED-BY        LAST-ADOPTION                  UPTIME
ap7532-A2A56C     5.9.2.0-010D   configured No   rfs4000-229D58 4 days 22:25:56     4 days 22:31:23
Total number of devices displayed: 1
rfs4000-229D58#
rfs4000-229D58(config)#customize show-adoption-status adopted-by ap-name config-
status last-adoption
rfs4000-229D58(config)#commit
The following example shows the shows the show > adoption > status command output after customizing the output:
Adopted by:
Type          : nx9000
Time
Adopted Devices:
ADOPTED-BY        DEVICE-NAME       CFG-STAT         LAST-ADOPTION
rfs4000-229D58 ap7532-A2A56C    configured        4 days 22:25:56
Use the no > customize > show-adoption-status command to revert back to the default format.
rfs4000-229D58(config)#no customize show-adoption-status
Adopted by:
Type          : nx9000
Adopted Devices:
rfs4000-229D58#
Related Commands
no
Restores custom CLI settings to default
