l2tpv3
Displays a L2TPv3 session information
This command is not available in the USER EXEC mode.
Syntax
show l2tpv3 {on|statistics|tunnel|tunnel-summary}
show l2tpv3 {on <DEVICE-NAME>}
show l2tpv3 statistics {on <DEVICE-NAME>)}
show l2tpv3 {tunnel <L2TPv3-TUNNEL-NAME>} {session <L2TPv3-SESSION-NAME>} {on <DEVICE-NAME>)}
show l2tpv3 {tunnel-summary} {down|on|up}
show l2tpv3 {tunnel-summary} {on <DEVICE-NAME>}
show l2tpv3 {tunnel-summary} {down|up} {on <DEVICE-NAME>}
Parameters
l2tpv3 {on <DEVICE-NAME>} Displays L2TPv3 tunnel and session details or summary
  • on <DEVICE-NAME> – Optional. Displays L2TPv3 information on a specified device
    • <DEVICE-NAME> – Specify the name of AP, wireless controller, or service platform.
Displays L2TPv3 Tunnel and session statistics. It displays the information, such as the number of packets transmitted and received, the rate of transmission, number of packets dropped, etc.
on <DEVICE-NAME>
Optional. Executes the command on a specified device
  • <DEVICE-NAME> - Specify the name of the access point, wireless controller, or service platform.
Note:
If you do not specify a device name, the system executes the command on the logged device.
show l2tpv3 {tunnel <L2TPv3-TUNNEL-NAME>} {session <L2TPv3-SESSION-NAME>} {(on <DEVICE-NAME>)}
l2tpv3 Displays L2TPv3 tunnel and session details or summary
tunnel <L2TPv3-TUNNEL- NAME> Optional. Displays a specified L2TPv3 tunnel information
  • <L2TPv3-TUNNEL-NAME> – Specify the L2TPv3 tunnel name.
session <L2TPv3-SESSION- NAME> Optional. Displays a specified L2TPv3 tunnel session information
  • <L2TPv3-SESSION-NAME> – Specify the session name.
on <DEVICE-NAME> The following keyword is recursive and common to the ‘session <L2TPv3-SESSION-NAME>' parameter.
  • on <DEVICE-NAME> – Optional. Displays a L2TPv3 tunnel and session details, based on the parameters passed, on a specified device.
Note: For an L2TPv3 tunnel over Auto IPSec, the tunnel status is displayed as: Established (secured by ipsec)
tunnel-summary {on <DEVICE-NAME>} Optional. Displays L2TPv3 tunnel summary
  • on <DEVICE-NAME> – Optional. Displays L2TPv3 tunnel summary on a specified device
tunnel-summary Optional. Displays L2TPv3 tunnel summary, based on the parameters passed
down Optional. Displays un-established tunnels summary
up Optional. Displays established tunnels summary
on <DEVICE-NAME> The following keyword is common to the ‘down' and ‘up' parameters:
  • on <DEVICE-NAME> – Optional. Displays summary, for un-established or established tunnels, on a specified device
ap7532-11E6C4#show l2tpv3 tunnel-summary
Sl No  Tunnel Name      Tunnel State            Estd/Total  Sessions   Encapsulation Protocol
1      testTunnel     Established (secured by ipsec)       1/1              IP
Total Number of Tunnels 1
ap7532-11E6C4#
Tunnel Name : testTunnel
  Control connection id : 2238970979
  Peer Address : 30.1.1.1
  Local Address : 30.1.1.30
  Encapsulation Protocol : IP
  MTU : 1460
  Peer Host Name : rfss
  Peer Vendor Name : Example Company
  Peer Control Connection ID : 322606389
  Tunnel State : Established (secured by ipsec)
  Establishment Criteria : always
  Sequence number of the next msg to the peer : 29
  Expected sequence number of the next msg from the peer :42
  Sequence number of the next msg expected by the peer : 29
  Retransmission count : 0
  Reconnection count : 0
  Uptime : 0 days 1 hours 2 minutes 47 seconds
  Session Name : session1
    VLANs : 30
    Pseudo Wire Type : Ethernet_VLAN
    Serial number for the session : 6
    Local Session ID : 129538998
    Remote Session ID : 8151374
    Size of local cookie (0, 4 or 8 bytes) : 0
    First word of local cookie : 0
    Second word of local cookie : 0
    Size of remote cookie (0, 4 or 8 bytes) : 0
    First word of remote cookie : 0
    Second word of remote cookie : 0
    Session state : Established
    Remote End ID : 444
    Trunk Session : 1
    Native VLAN tagged : Enabled
    Native VLAN ID : 0
    Number of packets received : 0
    Number of bytes received : 0
    Number of packets sent : 0
    Number of bytes sent : 0
    Number of packets dropped : 0
ap7532-11E6C4#
