passive
Configures specified OSPF interface as passive. This option is disabled by default.
A passive interface receives routing updates, but does not transmit them.
Syntax
passive [<WORD>|all|vlan <1-4094>]
Parameters
<WORD> Enables the OSPF passive mode on the interface specified by the <WORD> parameter
all Enables the OSPF passive mode on all the L3 interfaces
vlan <1-4094> Enables the OSPF passive mode on the specified VLAN interface
  • <1-4094> – Specify the VLAN interface ID from 1 - 4094.
nx9500-6C8809(config-profile default-ap8533-router-ospf)#passive vlan 1
nx9500-6C8809(config-profile default-ap8533-router-ospf)#show context
 router ospf
  ospf enable
  network 1.2.3.0/24 area 4.5.6.7
  area 0.0.0.4
  auto-cost reference-bandwidth 1
  default-information originate metric 1 metric-type 2
  passive vlan1
  ip default-gateway priority 1
Related Commands
no (router-mode-config-command) Disables the OSPF passive mode on a specified interface
