wips-policy
Configures a WIPS policy and enters its configuration
mode
- Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
Syntax
wips-policy <WIPS-POLICY-NAME>
Parameters
<WIPS-POLICY-NAME> |
Specify the WIPS policy name. If a policy with the specified name does
not exist, it is created. |
nx9500-6C8809(config)#wips-policy test
nx9500-6C8809(config-wips-policy-test)#?
Wips Policy Mode commands:
ap-detection Rogue AP detection
enable Enable this wips policy
event Configure an event
history-throttle-duration Configure the duration for which event duplicates
are not stored in history
interference-event Specify events which will contribute to smart-rf
wifi interference calculations
no Negate a command or set its defaults
signature Signature to configure
use Set setting to use
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
Related Commands
no
Removes an existing WIPS policy |
![Note](images/note.png)
For more information on WIPS Policy
commands, see
WIPS Policy.
