clrscr
Clears the screen and refreshes the prompt, irrespective of the mode
Syntax
clrscr
Parameters
None
The following example shows the terminal window or screen before the clrscr command is executed:
ap505-13403B>device-upgrade ?
  DEVICE-NAME     Name/MAC address of device
  all             Upgrade all devices
  ap505           Upgrade AP505 Device
  ap510           Upgrade AP510 Device
  cancel-upgrade  Cancel upgrading the device
  containing      Specify devices that contain a sub-string in the hostname
  load-image      Load the device images to controller for device-upgrades
  rf-domain       Upgrade all devices belonging to an RF Domain
ap505-13403B>
ap505-13403B>clrscr [ENTER]
The terminal window or screen after the clrscr command is executed:
ap505-13403B>
