pppoe-client
Displays PPPoE client information. Use this command to view PPPoE statistics derived from access to high-speed data and broadband networks. PPPoE uses standard encryption, authentication, and compression methods as specified by the PPPoE protocol. PPPoE enables point-to-points connection to an ISP over existing Ethernet interface.
Syntax
show pppoe-client [configuration|status] {on <DEVICE-NAME>}
Parameters
pppoe-client Displays PPPoE client information (configuration and status)
configuration Displays detailed PPPoE client configuration
status Displays detailed PPPoE client status
on <DEVICE-NAME> The following keywords are common to ‘configuration' and ‘status' parameters:
  • on <DEVICE-NAME> – Optional. Displays detailed PPPoE client status or configuration on a specified device
    • <DEVICE-NAME> – Specify the name of the AP, wireless controller, or service platform.
nx9500-6C8809#show pppoe-client configuration
 PPPoE Client Configuration:
|  Mode          : Disabled
|  Service Name  :
|  Auth Type     : pap
|  Username      :
|  Password      : fJx5O+5duPjaOaPuXmtLDQAAAAAmvgEXcQ1+eUK4ByHK4aRi
|  Idle Time     : 600
|  Keepalive     : Disabled
|  Local n/w     : vlan1
|  Static IP     : __wing_internal_not_set__
|  MTU           : 1492
nx9500-6C8809#
