netbios-node-type (dhcpv4-pool-config)
Defines the predefined NetBIOS node type. The NetBIOS node type resolves NetBIOS names to IP addresses.
Syntax
netbios-node-type [b-node|h-node|m-node|p-node]
Parameters
[b-node|h-node|m-node| p-node]
Defines the netbios node type
  • b-node – Sets the node type as broadcast. Uses broadcasts to query nodes on the network for the owner of a NetBIOS name.
  • h-node – Sets the node type as hybrid. Uses a combination of two or more nodes.
  • m-node – Sets the node type as mixed. A mixed node uses broadcasted queries to find a node, and failing that, queries a known p-node name server for the address.
  • p-node – Sets the node type as peer-to-peer. Uses directed calls to communicate with a known NetBIOS name server (such as a WINS server), for the IP address of a NetBIOS machine.
rfs4000-229D58(config-dhcp-policy-test-pool-testPool)#netbios-node-type b-node
rfs4000-229D58(config-dhcp-policy-test-pool-testPool)#show context
 dhcp-pool testPool
  network 192.168.13.0/24
  address 192.168.13.4 class dhcpclass1
  lease 100 23 59 59
  ddns server 192.168.13.9
  ddns domainname WID
  ddns multiple-user-class
  excluded-address range 192.168.13.25 192.168.13.28
  domain-name documentation
  bootfile test.txt
  default-router 192.168.13.8 192.168.13.9
  dns-server 192.168.13.19
  netbios-name-server 192.168.13.25
Related Commands
no
Removes the NetBIOS node type settings
