proxy-nd-mode
Configures the proxy ND mode for this
WLAN member clients as either strict or dynamic. ND proxy is used in IPv6 to provide
reachability by allowing a client to act as proxy. Proxy certificate signing can be done
either dynamically (requiring exchanges of identity and authorization information) or
statically when the network topology is defined.
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
proxy-nd-mode [dynamic|strict]
Parameters
| proxy-nd-mode [dynamic|strict] |
Configures the proxy ND mode for this WLAN member clients. The options are:
dynamic and strict
- dynamic – Forwards ND request
to wireless for which a response could not be proxied. This is the default
value.
- strict – Does not forward ND
requests to the wireless side
nx9500-6C8809(config-wlan-test)#proxy-nd-mode strict
nx9500-6C8809(config-wlan-test)#show context
wlan test
ssid test
bridging-mode tunnel
encryption-type none
authentication-type none
wpa-wpa2 server-only-authentication
opendns device-id 44-55-66
