redirection
Configures a list of destination ports (separated by commas, or using a dash for a range) that are taken into consideration when redirecting client connections
Syntax
redirection ports <LIST-OF-PORTS>
Parameters
Configures destination ports considered for redirecting client connection
A maximum of 16 ports can be specified in a comma-separated list. Standard ports 80 and 443 are always considered for client connections regardless of what‘s entered by the administrator.
rfs4000-229D58(config-captive-portal-test)#redirection ports 1,2,3
rfs4000-229D58(config-captive-portal-test)#show context
captive-portal test
 redirection ports 1-3
Related Commands
no
Disables redirection of client connection
