gre concentrator
gre
Creates a GRE Concentrator profile for supported ExtremeWireless WiNG controllers.
The GRE Concentrator feature supports GRE tunneling between APs and ExtremeWireless WiNG controllers.
With this feature, an AP acts as GRE initiator and creates wireless client tunnels to an ExtremeWireless WiNG controller that is operating as a GRE concentrator tunnel terminator.
The maximum limits on GRE tunnel terminations for controller platforms are as follows:
Platform Maximum GRE Tunnels Supported
NX5500 512
NX7500 1000
NX9610 1024
CX9000 Not suppported
VX9000 1024
Complete the following tasks to configure GRE tunneling between APs and ExtremeWireless WiNG controllers:
  1. Configure a GRE Concentrator profile for a supported controller.
  2. Configure VLANs for an AP.
    GRE Concentrator can terminate GRE tunnels mapped to more than one VLAN. You must configure one Native VLAN that is capable of transmitting untagged (default) or tagged traffic. All other VLANs will transmit tagged traffic. Select the Native VLAN when you configure the GRE tunnel profile in the next step.
  3. Configure the GRE peer-to-peer settings on the AP and try to reach the concentrator using the ping command.
Syntax
gre concentrator <GRE-CONC-TUNNEL>
Parameters
<GRE-CONC-TUNNEL> Specify the GRE concentrator name. If a GRE concentrator profile with the specified name does not exist, it is created.
Note: Only one GRE concentrator profile can be configured for a controller.
vx9000-AA3AED(config-profile-gre-conc-tunnel)#gre concentrator ?
  GRE-CONC-TUNNEL  Name of the GRE concentrator to be configured (will be
                   created if it does not exist)
vx9000-AA3AED(config-profile-gre-conc-tunnel)#gre concentrator gre-test
vx9000-AA3AED(config-profile-gre-conc-tunnel-gre-concentrator-gre-test)#?
GRE Concentrator Tunnel Mode commands:
  allowed-vlan  VLANs to tunnel
  idle-timeout  GRE tunnel inactivity timeout
  no            Negate a command or set its defaults
Related Commands
allowed-vlan Specifies the VLANs that are allowed to terminate GRE tunnels on the GRE concentrator
idle-timeout Specifies the GRE concentrator inactivity timeout
show gre {concentrator×€concentrator-tunnels} Displays GRE tunnel concentrator connection details.
no Disables GRE concentrator on this profile
