data-rates
Configuration the 802.11 rates
supported on this WLAN
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
data-rates [2.4GHz|5GHz|6GHz]
data-rates 2.4GHz [b-only|bg|bgn|custom|default|g-only|gn]
data-rates 2.4GHz custom [1|11|12|18|2|24|36|48|5.5|54|6|9|basic-1|basic-11|basic-12|
basic-18|basic-2|basic-24|basic-36|basic-48|basic-5.5|basic-54|basic-6|basic-9|
basic-mcs-1s|mcs-1s|mcs-2s|mcs-3s|basic-mcs-1s|basic-mcs0-7|mcs-1s|mcs-2s|mcs-3s|
mcs0-15|mcs0-23|mcs0-7|mcs16-23|mcs8-15|mcs8-23]
data-rates 5GHz [a-only|an|custom|default]
data-rates 5GHz custom [12|18|24|36|48|54|6|9|basic-1|basic-11|basic-12|basic-18|
basic-2|basic-24|basic-36|basic-48|basic-5.5|basic-54|basic-6|basic-9|basic-mcs-1s|
basic-mcs0-7|mcs-1s|mcs2s|mcs3s|mcs4s|mcs0-15|mcs0-23|mcs0-7|mcs16-23|mcs8-15|mcs8-23]
data-rates 6GHz (ax|default)
data-rates 6GHz custom {1s|2s|3s|4s|LIST|basic-6|basic-9|basic-12|basic-18|basic-24|basic-36|
basic-48|basic-54}
data-rates 6GHz custom {6|9|12|18|24|36|48|54|basic-1|basic-2|basic-5.5|basic-6|basic-9|basic-11|
basic-12|basic-18|basic-24|basic-36|basic-48|basic-54|mcs}
Parameters
data-rates 2.4GHz [b-only|bg|bgn|default|g-only|gn]
| data-rates |
Specifies the 802.11 rates supported when mapped to a 2.4 GHz
radio |
| b-only |
Uses rates that support only 11b clients |
| bg |
Uses rates that support both 11b and 11g clients |
| bgn |
Uses rates that support 11b, 11g and 11n clients |
| default |
Uses the default rates configured for a 2.4 GHz radio |
| g-only |
Uses rates that support operation in 11g only |
| gn |
Uses rates that support 11g and 11n clients |
data-rates 5GHz [a-only|an|default]
| data-rates |
Specifies the 802.11 rates supported when mapped to a 5.0 GHz
radio |
| a-only |
Uses rates that support operation in 11a only |
| an |
Uses rates that support 11a and 11n clients |
| default |
Uses default rates configured for a 5.0 GHz |
| data-rates |
Specifies the data rates supported when mapped to a 6.0 GHz
radio |
| ax |
Uses rates that support operation in 11ax only |
| default |
Uses default rates configured for a 6.0 GHz |
basic-12|basic-18|basic-2|basic-24|basic-36|basic-48|basic-5.5|basic-54|basic-6|
basic-9|basic-mcs-1s|mcs-1s|mcs-2s|mcs-3s|basic-mcs-1s|basic-mcs0-7|mcs-1s|mcs-2s|
mcs-3s|mcs0-15|mcs0-23|mcs0-7|mcs16-23|mcs8-15|mcs8-23]
| data-rates [2.4GHz|5GHz|6GHz] |
Specifies the 802.11 rates supported when mapped to a 2.4 GHz, 5.0 GHz,
or |6GHz radio |
| custom |
Configures a data rates list by specifying each rate individually. Use
'basic-' prefix before a rate to indicate it is used as a basic rate (For
example, 'data-rates custom basic-1 basic-2 5.5 11'). The data-rates for
2.4 GHz and 5.0 GHz channels are the same with a few exceptions. The 2.4
GHz channel has a few extra data rates: 1, 11, 2, and 5.5.
| 1,11,2,5.5 |
The following data rates are specific to the 2.4 GHz channel:
- 1 – 1-Mbps
- 11 – 11-Mbps
- 2 – 2-Mbps
- 5.5 – 5.5-Mbps
| 12,18,24,36,48,54,6,9, basic-1,basic-11, basic-12,basic-18, basic-2,
basic-36,basic-48, basic-5.5, basic-54,basic-6, basic-9,
basic-mcs0-7,mcs0-15, mcs0-7,mcs8-15 |
The following data rates are common to both the 2.4 GHz and 5.0 GHz
channels:
- 12 – 12 Mbps
- 18 – 18-Mbps
- 24 – 24 Mbps
- 36 – 36-Mbps
- 48 – 48-Mbps
- 54 – 54-Mbps
- 6 – 6-Mbps
- 9 – 9-Mbps
- basic-1 – basic
1-Mbps
- basic-11 – basic
11-Mbps
- basic-12 – basic
12-Mbps
- basic-18 – basic
18-Mbps
- basic-2 – basic
2-Mbps
- basic-36 – basic
36-Mbps
- basic-48 – basic
48-Mbps
- basic-5.5 – basic
5.5-Mbps
- basic-54 – basic
54-Mbps
- basic-6 – basic
6-Mbps
- basic-9 – basic
9-Mbps
- basic-mcs-1s –
Modulation and coding scheme data rates for 1 Spatial Stream
- mcs-1s – Applicable to
1-spatial stream data rates
- mcs-2s – Applicable to
2-spatial stream data rates
- mcs-3s – Applicable to
3-spatial stream data rates
nx9500-6C8809(config-wlan-test)#data-rates 2.4GHz gn
nx9500-6C8809(config-wlan-test)#show context
wlan test
ssid test
bridging-mode local
encryption-type none
authentication-type eap
accounting syslog host 172.16.10.4 port 2
client-load-balancing probe-req-intvl 5ghz 5
client-load-balancing band-discovery-intvl 2
captive-portal-enforcement fall-back
acl exceed-rate wireless-client-denied-traffic 20 disassociate
broadcast-dhcp validate-offer
