wireless-client
Configures the transmit power indicated to clients
Syntax
wireless-client [count-per-radio|cred-cache-ageout|hold-time|inactivity-timeout|
max-firewall-sessions|reauthentication|roam-notification|tx-power|t5-inactivity-timeout|
vlan-cache-out]
wireless-client [count-per-radio <0-256>|cred-cache-ageout <60-86400>|hold-time <1-86400>|
inactivity-timeout <60-86400>|max-firewall-sessions <10-10000>|reauthentication <30-86400>|
t5-inactivity-timeout <60-86400>|tx-power <0-20>|vlan-cache-ageout <60-86400>]
wireless-client roam-notification [after-association|after-data-ready|auto]
Parameters
hold-time <1-86400>|inactivity-timeout <60-86400>|max-firewall-sessions <10-10000>|
reauthentication <30-86400>|t5-inactivity-timeout <60-86400>|tx-power <0-20>|
wireless-client Configures the transmit power indicated to wireless clients for transmission
count-per-radio <0-256> Configures the maximum number of clients allowed on this WLAN per radio
  • <0-256> – Specify a value from 0 - 256.
cred-cache-ageout <60-86400> Configures the timeout period for which client credentials are cached across associations
  • <60-86400> – Specify a value from 60 - 86400 seconds.
hold-time <1-86400> Configures the time period for which wireless client state information is cached post roaming
  • <1-86400> – Specify a value from 1 - 86400 seconds.
inactivity-timeout <60-86400> Configures an inactivity timeout period in seconds. If a frame is not received from a wireless client for this period of time, the client is disassociated.
max-firewall-sessions <10-10000> Configures the maximum firewall sessions allowed per client on a WLAN
  • <10-10000> – Specify the maximum number of firewall sessions allowed from 10 - 10000.
reauthentication <30-86400> Configures periodic reauthentication of associated clients
  • <30-86400> – Specify the client reauthentication interval from 30 - 86400 seconds.
t5-inactivity-timeout <60-86400> Configures and inactivity timeout, in seconds, for T5 devices. When configured, the T5 device is disassociated if the time lapsed after the last frame received from it exceeds the value specified here.
  • <60-86400> – Specify a value from 60 - 86400 seconds. The default is 60 seconds.
tx-power <0-20> Configures the transmit power indicated to clients
  • <0-20> – Specify a value from 0 - 20 dBm.
vlan-cache-ageout <60-86400> Configures the timeout period for which client VLAN information is cached across associations.
roam-notification Configures when a roam notification is transmitted
after-association Transmits a roam notification after a client has associated
after-data-ready Transmits a roam notification after a client is data-ready (after completion of authentication, handshakes etc.)
auto Transmits a roam notification upon client association (if the client is known to have authenticated to the network)
nx9500-6C8809(config-wlan-test)#wireless-client cred-cache-ageout 65
nx9500-6C8809(config-wlan-test)#wireless-client hold-time 200
nx9500-6C8809(config-wlan-test)#wireless-client max-firewall-sessions 100
nx9500-6C8809(config-wlan-test)#wireless-client reauthentication 35
nx9500-6C8809(config-wlan-test)#wireless-client tx-power 12
nx9500-6C8809(config-wlan-test)#show context
wlan test
 ssid testWLAN1
 vlan-pool-member 1 limit 1
 vlan-pool-member 2 limit 1
 vlan-pool-member 3 limit 1
 vlan-pool-member 4 limit 1
 vlan-pool-member 5 limit 1
 vlan-pool-member 6 limit 1
 vlan-pool-member 7 limit 1
 vlan-pool-member 8 limit 1
 vlan-pool-member 9 limit 1
 vlan-pool-member 10 limit 1
 bridging-mode local
 encryption-type none
 authentication-type none
 protected-mgmt-frames mandatory
 wep64 key 1 hex 0 7465737431
 wep128 key 1 hex 0 25f6e7ed9718918a87a75acc75
 wep128 key 2 hex 0 2b3fb36924b22dffe98c86c315
 wep128 key 3 hex 0 1ebf3394431700194762ebd5b2
 wep128 key 4 hex 0 e3de75be311bd787aeac5e4e8b
 radius vlan-assignment
 time-based-access days weekdays start 10:00 end 16:30
 wing-extensions wmm-load-information
 client-load-balancing probe-req-intvl 5ghz 5
--More--
Related Commands
no (wlan-config-mode) Removes or reverts to default configured wireless client related parameters
