report-royalty-application
Enables detection of captive portal client‘s usage of a selected (preferred) loyalty application
Syntax
report-loyalty-application {custom-app <APPLICATION-NAME>}
Parameters
report-loyalty-application {custom-app <APPLICATION-NAME>} Reports a captive portal client‘s loyalty application presence and stores this information in the captive portal‘s user database. The client‘s loyalty application detection occurs on the access point to which the client is associated. Retail administrators can use this information to assess whether patrons‘ loyalty application usage is as per expectation within specific retail environments. This option is disabled by default.
  • custom-app <APPLICATION-NAME> – Optional. Uses a custom application definition as match criteria.
    • <APPLICATION-NAME> – Specify the custom application name (should be existing and configured). Ensure that the application specified is available and configured. If not, create an application definition. For more information, see application.
If no custom application definition is specified, the system uses localization to detect application presence.
nx9500-6C8809(config-captive-portal-test)#report-loyalty-application custom-app
AntiVirus
nx9500-6C8809(config-captive-portal-test)#show context include-factory | include
 report-loyalty-application custom-app AntiVirus
Related Commands
no Disables detection of customer-loyalty application presence
