About Common Commands
Common commands are called as such because they are applicable to USER EXEC, PRIV EXEC, and GLOBAL CONFIG modes.
The PRIV EXEC command set contains commands available within the USER EXEC mode. Some commands can be entered in either mode. Commands entered in either the USER EXEC or PRIV EXEC mode are referred to as EXEC mode commands. If a user or privilege is not specified, the referenced command can be entered in either mode.
