broadcast-ssid
Advertises the WLAN SSID in beacons. If a hacker tries to isolate and hack a SSID from a client, the SSID will display since the ESSID is in the beacon. This feature is enabled by default.
Syntax
broadcast-ssid
Parameters
None
nx9500-6C8809(config-wlan-1)#broadcast-ssid
Related Commands
no (wlan-config-mode) Disables the broadcasting of the WLAN‘s SSID in beacons
