Moving the Cursor on the Command Line
The following table shows the key combinations or sequences to move the command line cursor. Ctrl defines the control key, which must be pressed simultaneously with its associated letter key. Esc means the escape key (which must be pressed first), followed by its associated letter key. Keys are not case sensitive. Specific letters are used to provide an easy way of remembering their functions. The bold characters indicate the relation between a letter and its function.
Table: Keystrokes Details
Keystrokes
Function Summary
Function Details
Left Arrow
or
Ctrl-B
Back character
Moves the cursor one character to the left
When entering a command that extends beyond a single line, press the Left Arrow or Ctrl-B keys repeatedly to move back to the system prompt.
Right Arrow or Ctrl-F
Forward character
Moves the cursor one character to the right
Esc- B
Back word
Moves the cursor back one word
Esc- F
Forward word
Moves the cursor forward one word
Ctrl-A
Beginning of line
Moves the cursor to the beginning of the command line
Ctrl-E
End of line
Moves the cursor to the end of the command line
Ctrl-D
Deletes the current character
Ctrl-U
Deletes text up to cursor
Ctrl-K
Deletes from the cursor to end of the line
Ctrl-P
Obtains the prior command from memory
Ctrl-N
Obtains the next command from memory
Esc-C
Converts the letter at the cursor to uppercase
Esc-L
Converts the letter at the cursor to lowercase
Esc-D
Deletes the remainder of a word
Ctrl-W
Deletes the word up to the cursor
Ctrl-Z
Returns to the root prompt
Ctrl-T
Transposes the character to the left of the cursor with the character located at the cursor
Ctrl-L
Clears the screen
