static-route (dhcpv4-pool-static-binding)
Adds static routes to the static binding configuration. Use this option to add static routes installed on clients.
Syntax
static-route <IP/Mask> <Gateway-IP>
Parameters
<IP/Mask>
Specifies the IP destination prefix (for example, 10.0.0.0/8)
<Gateway-IP>
Specifies the gateway IP address
nx9500-6C8809(config-dhcp-policy-test-pool-pool1-binding-1)#static-route 10.0.0.0/10 157.235.208.235
nx9500-6C8809(config-dhcp-policy-test-pool-pool1-binding-test)#show context
  static-binding client-identifier test
   client-name RFID
   domain-name documentation
   netbios-node-type b-node
   netbios-name-server 172.16.10.23
   next-server 172.16.10.24
   option option1 172.16.10.10
   respond-via-unicast
Related Commands
no (dhcpv4-pool-static-binding)
Resets values or disables DHCP pool static binding settings
