BGP peers and route maps can reference a single IP based ACL (access control list). Apply IP ACLs to both inbound and outbound route updates. When applied to a BGP enabled router, every route update is passed through the ACL. Each ACL contains deny and permit entries that are applied sequentially, in the order they appear within the list. When a route matches an entry, the decision to permit or deny the route is applied. Once a match is made the remaining entries in the ACL are not processed.
<DEVICE>(config)#bgp ip-access-list <IP-ACL-NAME>
<DEVICE>(config-bgp-ip-access-list-<IP-ACL-NAME>)#? BGP IP Access List Mode commands: deny Specify packets to reject no Negate a command or set its defaults permit Specify packets to forward clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal <DEVICE>(config-bgp-ip-access-list-<IP-ACL-NAME>)#
| Command | Description |
| deny (bgp-ip-access-list) | Creates and configures a deny entry rule for this BGP IP ACL |
| permit (bgp-ip-access-list) | Creates and configures a permit entry for this BGP IP ACL |
| no (bgp-ip-acess-list) | Removes a deny or permit entry from this BGP IP ACL |
