wips
interface-config-radio-instance
Enables access point to change its channel of operation in order to terminate rogue devices. The radio should be configured to provide WLAN service.
This option is enabled by default.
Syntax
WiNG access points use Smart RF to perform off-channel scans. Therefore, ensure that a Smart RF policy is configured and applied to the access points RF Domains to enable them perform rogue detection and termination.
wips airtime-termination [allow-channel-change|spectrum-management-strict]
Parameters
wips airtime-termination allow-channel-change Enables access point to change its channel of operation (to that of the rogue device) in order to terminate the rogue device
spectrum-management-strict Enables the processing of spectrum management capability of an AP before performing air-termination
nx9500-6C8809(config-profile-testAP510-if-radio1)#wips air-termination allow-channel-change
Related Commands
no (radio-interface-config-command) Disables access point to change its channel of operation in order to terminate rogue devices
