use
Uses CRM (Critical Resource Monitoring) to monitor link status
Syntax
use critical-resource-monitoring
Parameters
use critical-resource-monitoring Uses CRM to monitor the status of a link. Selecting this option determines the disposition of the route-map next hop via monitored critical resources. Link monitoring is the function used to determine a potential fail over to the secondary next hop. This option is enabled by default.
nx9500-6C8809(config-routing-policy-testpolicy)#use critical-resource-monitoring
Related Commands
no (routing-policy-config-mode-command) Disables CRM link status monitoring
