mac-auth
interface-config-ge-instance
Enables authentication of MAC addresses on the selected wired port. When enabled, this feature authenticates the MAC address of a device, connecting to this interface, with a RADIUS server. When successfully authenticated, packets from the source are processed. Since only one MAC address is supported per wired port, packets from all other sources are dropped.
For more information on enabling this feature, see mac-auth.
Enable port MAC authentication in conjunction with Wired 802.1x settings to configure a MAC authentication AAA policy.
This option is also available in the device configuration mode.
Syntax
mac-auth
Parameters
None
nx9500-6C8809(config-profile-testnx5500-if-ge1)#mac-auth
nx9500-6C8809(config-profile-testnx5500-if-ge1)#show context
 interface ge1
  mac-auth
  ip dhcp trust
  qos trust dscp
  qos trust 802.1p
  channel-group 1
 interface ge5
  switchport mode access
  switchport access vlan 1
  dot1x authenticator host-mode single-host
  dot1x authenticator guest-vlan 5
  dot1x authenticator port-control auto
  mac-auth
Related Commands
no Disables authentication of MAC addresses on the selected wired port
