flow
Defines the session flow timeout interval for different packet types
Syntax
flow [dhcp|timeout]
flow dhcp stateful
flow timeout [icmp|other|tcp|udp]
flow timeout [icmp|other] <1-32400>
flow timeout udp <15-32400>
flow timeout tcp [close-wait|reset|setup|stateless-fin-or-reset| stateless-general] <1-32400>
flow timeout tcp established <15-32400>
Parameters
flow dhcp stateful
dhcp
Configures DHCP packet flow
stateful
Performs a stateful check on DHCP packets. This feature is enabled by default.
timeout
Configures a packet timeout
icmp
Configures the timeout for ICMP packets. The default is 30 seconds.
other
Configures the timeout for packets other than ICPM, TCP, or UDP. The default is 30 seconds.
<1-32400>
Specify the timeout from 1 - 32400 seconds.
timeout
udp
Configures the timeout for UDP packets. The default is 30 seconds.
<15-32400>
Specify the timeout from 15 - 32400 seconds.
flow timeout tcp [close-wait|reset|setup|stateless-fin-or-reset|stateless-general] <1-32400>
timeout
tcp
Configures the timeout for TCP packets
close-wait
Configures the closed TCP flow timeout. The default is 10 seconds.
reset
Configures the reset TCP flow timeout. The default is 10 seconds.
setup
Configures the opening TCP flow timeout. The default is 10 seconds.
Configures stateless TCP flow timeout created with the FIN or RESET packets. The default is 10 seconds.
stateless-general
Configures the stateless TCP flow timeout. The default is 90 seconds (1 m 30s).
<1-32400>
timeout
Configures the packet timeout
tcp
established
Configures the established TCP flow timeout. The default is 5400 seconds.
<15-32400>
nx9500-6C8809(config-fw-policy-testFW)#flow timeout udp 10000
nx9500-6C8809(config-fw-policy-testFW)#flow timeout icmp 16000
nx9500-6C8809(config-fw-policy-testFW)#flow timeout other 16000
nx9500-6C8809(config-fw-policy-testFW)#flow timeout tcp established 1500
nx9500-6C8809(config-fw-policy-testFW)#show context
firewall-policy testFW
 no ip dos tcp-sequence-past-window
 dhcp-offer-convert
 alg facetime
 dns-snoop entry-timeout 1200
Related Commands
no Removes session timeout intervals configured for different packet types
