override-smart-rf
Enables dynamic channel switching for Smart RF radios. This command allows you to configure an override list of channels that Smart RF can use for channel compensations on 2.4 GHz, 5.0 GHz, or 6.0 GHz radios.
When a radio fails or is faulty, a Smart RF policy provides automatic recovery by instructing neighboring access points to increase their transmit power to compensate for the coverage loss. Once correct access point placement has been established, Smart-RF can optionally be leveraged for automatic detector radio selection. Smart-RF uses detector radios to monitor RF events and can ensure availability of adequate detector coverage.
Syntax
override-smartrf channel-list [2.4GHz|5GHZ|6GHZ] <CHANNEL-LIST>
Parameters
override-smartrf Enables dynamic channel switching for Smart RF radios
channel-list Configures a list of channels for 2.4 GHz, 5.0 GHz, or 6.0 GHz Smart RF radios
2.4GHz <CHANNEL-LIST> Selects the 2.4 GHz Smart RF radio channels
  • <CHANNEL-LIST> – Specify a list of channels separated by commas.
5GHz <CHANNEL-LIST> Selects the 5.0 GHz Smart RF radio channels
6GHz <CHANNEL-LIST> Selects the 6.0 GHz Smart RF radio channels
nx9500-6C8809(config-rf-domain-default)#override-smartrf channel-list 2.4GHz 1,2,3
nx9500-6C8809(config-rf-domain-default)#show context
rf-domain default
 contact Bob+14082778691
 country-code us
 layout area Ecospace floor Floor1 map-location www.firstfloor.com units meters
Related Commands
no (rf-domain-config-mode) Removes the override-smartrf list of channels configured for 2.4 GHz, 5.0 GHz, or 6.0 GHz radios
