Important
This feature is supported only on APs with USB ports. Ensure the AP is using PoE+ (802.3at) power for the USB port.
Your AP will not communicate with the ESL server with any exisiting or older versions of Imagotag configuration.ESL tags are small, battery-powered devices used by retail businesses to display information, such as product code, pricing, and more. These tags are activated, configured, and managed through an SES-Imagotag server. The tags and server communicate through an ESL communicator (a USB dongle) connected to the USB port on the WiNG AP. This communication is over the 2.4 GHz band using a proprietary RF protocol. The ESL communicator acts as a bridge between the tags and the server, using WiNG AP as an infrastructure device.
This policy enables the ESL communicator, identifies the Imagotag server host, configures the payload size, and more. Apply the policy to the AP‘s self (in case of stand-alone AP) or profile context. When applied to the profile, the policy is pushed to the AP through the adopting controller.
Important
On the Imagotag server, configure the WiNG AP's ID. This enables the server identify the WiNG AP. Use theshow > iot-device-type-imagotag >
status command to obtain the WiNG AP's ID. Refer to the Imagotag server
configuration guide for more information.iot-device-type-imagotag-policy <POLICY-NAME>
| iot-device-type-imagotag-policy <POLICY-NAME> | Specify an IoT Device-type Imagotag policy name. If a policy by the specified name does not exist, it is created. |
nx5500-85FA27(config-iot-device-type-imagotag-policy-Default)#?
Iot Imagotag Policy Mode commands:
ap-id Configure AP ID
channel Configure ESL channel
enable Enable ESL communicator
fcc-mode Enable fcc compatibility mode on ESL communicator
no Negate a command or set its defaults
output-power Maximum output power
payload-size Configure payload size
server ESL server
ssl Enable ssl on ESL communicator
ssl-cn-verify Enforce SSL Common Name attribute verification
ssl-strict-verify Enforce SSL strict verification
trustpoint Trustpoint for server CA certificate
window-size Configure window size
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
You must upgrade your existing on-prem ESL server and add new parameters to theiot-device-type-imagotag-policy
to enable a secure connection.
Ensure that your ESL server is migrated to latest version supporting outbound connection mode and encrypted communication support.| no | Deletes the specified IoT Device Type Imagotag policy |
