schedule-policy
Creates a schedule policy and enters its
configuration mode. A schedule policy strategically enforces application filter policy rules
during administrator assigned intervals.
- Access Points — AP410i/e
AP460i/e, AP505i, AP510i/e, AP560i/h, AP7602, AP7612, AP7622, AP7632, AP7662,
AP8533
- Service Platforms —
- Virtual Platforms —
CX9000, VX9000
Syntax
schedule-policy <SCHEDULE-POLICY-NAME>
Parameters
| schedule-policy <SCHEDULE-POLICY-NAME> |
Specify the Schedule policy name. If a policy with the specified name does not
exist, it is created. The name should not exceed 32 characters in length. |
nx9500-6C8809(config)#schedule-policy test
nx9500-6C8809(config-schedule-policy-test)#?
Schedule Policy Mode commands:
description Schedule policy description
no Negate a command or set its defaults
time-rule Configure a time rule
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
Related Commands
| no |
Removes an existing schedule policy |
