dynamic-chain-selection
interface-config-radio-instance
Enables dynamic chanin selection. When enabled, the radio can dynamically change the number of transmit chains used (uses a single chain/antenna for frames at non-11n transmit rates). This option is enabled by default.
Syntax
dynamic-chain-selection {strict}
Parameters
dynamic-chain-selection {strict} Enables dynamic chain selection.
  • strict – Optional. Uses strict antenna-mode selection (single antenna for non-11n transmit rates)
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#dynamic-chain-selection
Related Commands
no (radio-interface-config-command) Uses the configured transmit antenna mode for all clients
