use
Configures a tunnel to use a specified L2TPV3 tunnel policy and specified critical resources
Syntax
use [critical-resource|l2tpv3-policy]
use critical-resource <CRM-NAME1> {<CRM-NAME2>} {<CRM-NAME3>} {<CRM-NAME4>}
use l2tpv3-policy <L2TPV3-POLICY-NAME>
Parameters
Specifies the critical resource(s) to use with this tunnel
  • <CRM1-NAME> – Specify the first critical resource name (should be existing).
  • <CRM-NAME2/3/4> – Optional. Specify the second/third/fourth critical resource names. Maximum of four critical resources can be monitored.
Note: In case of tunnel initiator, L2TPv3 tunnel is established only if the critical resources identified by the <CRM-NAME1>.................. <CRM-NAME4> arguments are available at the time of tunnel establishment.
Note: In case of L2TPv3 tunnel termination, all incoming tunnel establishment requests are rejected if the critical resources specified by the <CRM-NAME1>.............. <CRM-NAME4> arguments are not available.
Associates a specified L2TPV3 policy with this tunnel
  • <L2TPV3-POLICY-NAME> – Specify the policy name.
nx9500-6C8809(config-profile default-nx5500-l2tpv3-tunnel-Tunnel1)#use l2tpv3-policy L2TPV3Policy1
nx9500-6C8809(config-profile default-nx5500-l2tpv3-tunnel-Tunnel1)#show context
 l2tpv3 tunnel Tunnel1
  peer 2 hostname tunnel1peer1 udp port 100
  session tunnel1peer1session1 pseudowire-id 5000 traffic-source vlan 10-20 native-vlan 1
  router-id 2000
  establishment-criteria cluster-master
Related Commands
no
Removes the L2TPV3 policy configured with a tunnel and reverts to the default tunnel policy
