peer
Configures the L2TPv3 tunnel‘s peers. At least one peer must be specified.
Syntax
peer <1-2> {hostname|ip-address|ipsec-secure|router-id|udp}
peer <1-2> {hostname [<HOSTNAME>|any]} {ipsec-secure|router-id|udp}
peer <1-2> {ip-address <IP>} {hostname|ipsec-secure|router-id|udp}
peer <1-2> {ipsec-secure} {gw [<IP>|<WORD>]}
peer <1-2> {router-id [<IP>|<WORD>|any]} {ipsec-secure|udp}
peer <1-2> {udp} {ipsec-secure|port <1-65535>}
Parameters
peer <1-2>
Configures the tunnel‘s peer ID
  • <1-2> – Specify the ID from 1 - 2. The peer ID identifies the primary (ID 1) secondary (ID 2) peers. The L2TPv3 tunnel is established with the primary peer. The secondary peer is used for tunnel failover. If the peer is not specified, tunnel establishment does not occur.
Note: At any time the tunnel is established with only one peer, unless fast-failover support is configured on the L2TPv3 tunnel. For more information, see fast-failover.
Optional. Configures the peers‘ hostname. The hostname options are:
  • <HOSTNAME> – Specifies the hostname as FQDN (Fully Qualified Domain Name) or partial DN or any other name
  • any – Peer name is not specified. If the hostname is ‘any‘ this tunnel is considered as responder only and will allow incoming connection from any host.
ipsec-secure {gw [<IP>|<WORD>]}
After specifying the peer hostname, optionally specify the IPSec settings:
  • ipsec-secure – Optional. Enables auto IPSec on the L2TPv3 tunnel
    • gw – Optional. Configures the IPSec gateway. Use one of the following options to configure the IPSec gateway:
      • <IP> – Configures IPSec gateway‘s IP address
      • <WORD> – Configures IPSec gateway‘s hostname
After specifying the peer hostname, optionally specify router ID settings:
  • router-id – Optional. Configures the peer‘s router ID in one of the following formats:
    • <IP> – Peer router ID in the IP address (A.B.C.D) format
    • <WORD> – Peer router ID range (for example, 100-120)
    • any – Peer router ID is not specified. This allows incoming connection from any router ID.
udp {ipsec-secure gw|port <1-65535> {ipsec-secure}}
After specifying the peer hostname, optionally specify UDP settings:
The UDP option configures the encapsulation mode for this tunnel.
  • UDP – Optional. Configures UDP encapsulation (default encapsulation is IP)
    • ipsec-secure gw – Optional. Enables auto IPSec
    • port <1-65535> {ipsec-secure} – Optional. Configures the peer‘s UDP port running the L2TPv3 service from 1 - 65535. After specifying the peer UDP port, optionally configure the IPSec settings.
peer <1-2>
Configures the tunnel‘s peer ID from 1 - 2. At any time the tunnel is established with only one peer.
ip-address <IP>
Optional. Configures the peer‘s IP address in the A.B.C.D format
  • <IP> – Specify the peer‘s IP address.
hostname [<FQDN>|any]
After specifying the peer IP address, optionally specify the peer‘s hostname:
  • <FQDN> – Specifies the hostname as FQDN or partial DN
After specifying the peer IP address, optionally specify the IPSec settings:
router-id [<A.B.C.D>|<WORD>| any]
After specifying the peer IP address, optionally specify the router ID using one of the following options:
  • router-id – Optional. Configures the peer‘s router-id in one of the following formats:
    • <A.B.C.D> – Peer router ID in the IP address (A.B.C.D) format
After specifying the peer IP address, optionally specify the peer‘s UDP port settings:
    • port <1-65535> – Optional. Configures the peer‘s UDP port running the L2TPv3 service from 1 - 65535. After specifying the peer UDP port, optionally configure the IPSec settings.
peer <1-2>
Optional. Enables auto IPSec for this peer
peer <1-2>
Configures the tunnel peer ID from 1 - 2. At any time the tunnel is established with only one peer.
After specifying the peer‘s router ID, optionally specify the IPSec settings.
udp {ipsec-secure gw| port <1-65535> {ipsec-secure}}
peer <1-2>
udp {ipsec-secure| port <1-65535> {ipsec-secure}}
Optional. Configures UDP encapsulation for this tunnel‘s pee (default encapsulation is IP)
  • ipsec-secure – Optional. Configures IPSec gateway on this peer UDP port
nx9500-6C8809(config-profile default-nx5500-l2tpv3-tunnel-Tunnel1)#peer 2 hostname tunnel1peer1 udp port 100
nx9500-6C8809(config-profile default-nx5500-l2tpv3-tunnel-Tunnel1))#show context
 l2tpv3 tunnel Tunnel1
  establishment-criteria cluster-master
Related Commands
no
Removes the peer configured for this tunnel
