enable
Turns on (enables) the privileged mode command set. The prompt changes from ap510-133B3B> to ap510-133B3B#. This command does not do anything in the Privilege Executable mode.
Syntax
enable
Parameters
None
ap510-133B3B>enable
ap510-133B3B#
