local-as (bgp-neighbor-config)
Configures this neighbor‘s local AS number
Syntax
local-as <1-4294967295> {no-prepend}
Parameters
local-as <1-4294967295> {no-prepend} Configures the local AS number
  • <1-4292967295> – Specify a value from 1 - 4294967295.
    • no-prepend – Optional. Select to enable. When enabled, the local AS number is not prepended to route updates from eBGP peers. AS numbers are prepended to route updates by default.
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#local-as 20 no-prepend
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#show context
  bgp neighbor 192.168.13.99
   advertisement-interval 100
   allowas-in 10
   attribute-unchanged as-path
   capability orf prefix-list both
   default-originate
   description neighbor "This neighbor is an external AS neighbor"
   disable-connected-check
   dont-capability-negotiate
   ebgp-multihop 20
   enforce-multihop
Related Commands
no (bgp-neighbor-config) Removes the local AS number. And also reverts prepending of AS numbers to default (allows prepending).
