action
Specifies the action invoked on the client once it reaches a specified threshold value. The threshold values are configured based on the client load.
Syntax
action [assisted-roam|deauth|log]
Parameters
action [assisted-roam|deauth|log] Configures the action invoked on the client once it reaches the specified threshold value. The options are:
  • assisted-roam – Provides 802.11v assisted roaming facility to the client
  • deauth – De-authenticates the client. This is the default setting.
  • log – Generates a log
Note: In all three cases an event is generated. However, the message generated differs and is based on the action specified.
nx9500-6C8809(config-roaming-assist-policy-test)#action log
nx9500-6C8809(config-roaming-assist-policy-test)#show context
roaming-assist-policy test
 action log
Related Commands
no Removes the configured action details
